Cydia won't load fully over home WiFi
Chop
57
I have a bit of a weird situation here:
My iPad (3rd gen) works fine on either wifi or cellular for all apps. However, when I load Cydia, if I'm on my home WiFi, Cydia will never fully load. I get spinning wheels, timeouts, and blank screens. I have to turn WiFi off and then it works flawlessly over cellular. This only happens on my home WiFi - anywhere else, Cydia loads like a champ.
The strange thing is that I don't have this issue with my iPhone, which is on the same network (obviously), same firmware (5.1.1), same JB version, etc. Cydia loads perfectly. I just don't get it - am I missing something obvious? I didn't have this issue with my iPad 2 (WiFi only), but I have with both of my new iPads (4G).
1982ollie
711
33
That is weird. The first thing that I would try is restoring and re jailbreaking because if it's just Cydia, then it might be something to do with the jailbreak or something has gone weird because of something that you have installed, like a tweak or something. Has it always been like that since you jailbroke?
3cit
3,044
63
Do you have different repositories on each device? I'll bet you have at least one additional one on your iPad that is causing this mess
sherlock
1,685
64
You can just reinstall Cydia without the restore/rejailbreak.
3cit
3,044
63
I hate when op's disappear!! Where's the resolution here! It's like a show being cancelled mid season in the middle of a plot line...
3cit
3,044
63
We all are! Nobody knows why king fu's Cydia won't load!! And he has disappeared... I think we have the sequel To tron here... "Tron iOS"
Jerrytg4
