need help with quickpwn
Jandis
Mar 2, 2009
Hi im trying to jail break my phone with quickpwn but then i get to a step where it ask's me to locate the firmware bundles... i dont know where that is. anyone know where i can get it or how to find it.. from what i know most peoples it locates it for them.. not my case. thx
Jeremy
Retired Moderator
Mar 27, 2005
6,807
251
www.iMore.com
Have you downloaded the correct firmware file? If you have it should find it. If not you can manually browse to it.
Jandis
Mar 2, 2009
Not sure
where do i download the correct firmware? i downloaded the file off of the blog.dev team site..... i thought that would be enough..... what else should and where should i download from? thx
RowanJack
