iPhone 4 Verizon SMS and data problems
iphone-5
May 7, 2012
9
Hi I have iPhone 4verizon flashed at reliance telecom it 5.0.1 jail broken I had problems with SMS and data service I am unable to send SMS and data is not working and also I am unable to see the saved contact names while incoming calls plz help if someone has any solution
kch50428
21,025
305
Any one there
Are you trying to run this phone on Verizon? Or another carrier?
If on Verizon - you need to totally erase the phone and reinstall the OS and restore as new via iTunes... if you're trying to use it on another carrier - it will be very difficult to access the phone's OS network provider set-up files and put in the necessary information for the other carrier's network.
Garz
Retired Moderator
Mar 9, 2009
8,172
155
37
I'm clueless on what your asking. You said you have a Vzn iPhone 4 flashed at reliance telecom. Huh???
Peligro911
5,878
136
Sounds like your flash was not done properly
Beamed from my iPad 2 routed and bouncing across the globe on multiple servers and brought to you using Tapatalk !
iphone-5
May 7, 2012
9
Thanks for the reply....
Yes I am using it on other carrier(not on Verizon) I want to set my data settings if u have any information plz share
kch50428
21,025
305
You're going to have to find someone on reliance telecom that has a fully working iPhone and have them help you.
SarahWilkerson
