Iphone 3gs Lockscreen Problem!Help!
jaymit
Oct 12, 2010
11
Hey Everyone,
I have jailbroken my iPhone with redsnow,i have a iPhone 3gs in IOS 4.3.1.And i have installed a winterboard .But i have a problem .
every time i install a Lock-screen Theme for my iPhone the old lock from the lock-screen doesn't get removed and it looks very ugly and bad
I have attached a image below and i have circle my old lock of my lock-screen
I am sure you'll understand my problem once you view the image attached!
I want to remove it can you please help me!! I cant find a tweak for removing just the original lock of the iPhone and not disabling the whole lock screen ,so that i can see the theme lock part
can any1 help me!!
Massie
5,063
332
83
The file name for that image was changed in 4.3.1, I believe it's now called WellLock or something similar. You may need to alter the theme with a transparent WellLock image.
jaymit
Oct 12, 2010
11
Thanks a lot i googled wellock and i got a site that gave me instruction on ho to do so !!!You were a great help!:)
Here is the solution if any1 has the problem:
Download this zip file from here : h t t p :// c l . l y / 5 k Z e
(Remove space from url)
If you ssh into Themes/themesxxx/Bundles/com.apple.Telephonyui
and add these 4 files which you download from this link.
(I did not make these files,they were made by Jkauf55)
You will find that your slider will become transparent and therefore
will be able to use animated lockscreen.
You can use these files for any theme if you are on ios 4.3.1
Hope this helps cos it solved my problem of theming since upgrading
to the latest firmware !!!
Source: h t t p :// www . sinfuliphone . com / showthread . php?p=517694
(Remove space here to get url)
williams77
