How fix Grey color bars on display iPad Air 2
I
iMore Question
Used my IPad Air 2 this AM was working normal. This PM turned on and observe three vertical Grey bars on display. Performed shut down 3 different times (waited approximately 5 minutes in between). the iPad battery is fully charged and has IOS 12.1.3 software.
How can thisbefixed? Maybe perform factory reset?
59,790
647
It’s possible unless the problem is hardware-related. Since I don’t know your level of experience with technology, I recommend you make a Genius Bar appointment with the nearest Apple Store for have them diagnose the problem for you.
Annie_M
Mar 2, 2016
22,006
784
I agree 100%. An appointment with the Genius Bar or a contacting Apple Support would be best. Good luck and keep us posted. Also, consider registering here at iMore.
