Why is there no audio on incoming and outgoing calls until I put it on speakerphone?
I
iMore Question
i did the update and i took the battery out but no results its fine only if i put it on speaker
59,790
647
Re: no audio on phone on incoming and out going calls until i put it on speakerphone
Is it safe to assume you're not using an iPhone since you took the battery out? If you're using an Android device, please post your question via http://forums.androidcentral.com.
59,790
647
Why is there no audio on incoming and outgoing calls until I put it on speake...
Anyway, is the phone getting connected to a Bluetooth device that you're not using at the time?
Dennis Anderson Julien
