Iphone X auto reatarting and draining battery to 0%
meedasg
Apr 16, 2019
Hi All,
I have recently faced a problem with my iphone x please look at bellow at the failiures i have come across.
1. my phone suddenly was restarting all time and not accepting charge.
the following is what i did i changed charging port, the battery and also reinstalled IOS 12,2 the phone had reboot well after few hours i started getting ghost touch my screen was getting command without a touch than after the phone restarted and totally drained battery again to 0% i put the phone on DFU and reinstalled IOS 12.2 again after restart was a success than 5 mins later same issue again i believe its something to do with the hardware after looking around 3utools the phone looks refurbished but i still dont understand why is this issue rising after allnew hardware replaced and i have fixed so many iphone x without fail i have also managed to change IC on the lower phones for this one since i had another iPhone x which was broken i just switched those two parts as mentioned above can you please assist me here on this matter.
Regards
AR
pkcable
Q&A Team Leader, VR Expert
Jun 16, 2009
5,827
28
The symptoms you are describing can happen to a water or moisture damaged phone. Has the phone been dropped or exposed to any kind of water or moisture?
meedasg
Apr 16, 2019
thank you for getting back, well i am not sure i sort of had a hunch about that ill have to ask the person who gave me the phone ill surely revert back but so far the phone just fluctuates from 78% to zero than again the ghost touch appears same all rotation.
thank you for replying ill inform you where i reach on this.
saiprasad
