My sound is off. Muted not volume turned down. Help?
nikkisharif
Jun 2, 2011
8,563
42
48
Check the mute switch on the side of the phone above the volume buttons & make sure it's not turned on. If it's on turn it off & your sound should work.
RobbyRob
135
This was a popular problem on the older iPhones with the old charging ports. The thing would get stuck in dock mode and the sound wouldn't play. Might be something to look into.
smitty22d2
