wifi problem
bnoles
Dec 1, 2008
I bought my wife and I iPhones Last Friday. I was able to sync up our home wifi to both phones with no problems. Last night I was down loading updates for apps over the wifi on my phone and it locked up for a short time. Then dropped the wifi and went to 3g. Since then I have not been able to connect my phone to my home wifi. My phone shows a weak signal and when I try to connect it says that it is unable to connect to network. I checked my wife's phone - no problem. Her phone has a great signal for wifi. Reset my router. Restored my iphone through itunes - still the same. At this point I am unsure what to do. Didn't know if it was a hardware or softwear problem with the phone. Any help would be great - thanks.
Jeremy
Retired Moderator
Mar 27, 2005
6,807
251
www.iMore.com
I had this happen to me on my first iPhone. Could not get it to work for the life of me. Just stopped in a Apple store and they swapped it out with no issues. New one worked perfectly fine. Sorry I could not be of more help.
jamesus
TiPb Forum Staff
Jul 10, 2008
1,818
11
Sounds like you performed all of the steps that I would have done. Next step is to do what Bad Ash posted. Just make sure your iPhone isn't jailbroken when you bring it back!
