General and mail problems
Sep 9, 2015
5
I just switched Over from BlackBerry10 and I am really frustrated. Is there a way to show just unread email messages? On BB all I need to do is pinch in the hub and all the read emails go away.
Also, is there a way so i don't have to refresh manually to load new emails?
Also, is there a way to share photos from the photo app, like to Facebook or a friend?
59,790
647
Re: General and mail peoblems
Natively? No. It may be possible with a 3rd-party Mail app, but I'm unaware of any, if available.
If your email account support push notifications then your emails should refresh as soon as new email arrives.
Yes. From within the Photos app, select the pic you want to share and then select the share icon at the bottom and then select Facebook.
SwitchBeach
2,968
6
You can view Unread messages with no problems. In the Mail app, touch "Edit" in the top right corner. Make sure "Unread" has a checkmark next to it. Press "Done".
Rmorton0573
81
To answer question 2, most likely your mail does not "push" such as Gmail. So the data will have to be fetched. Select Settings and Mail, Contacts, Calendars. Select Fetch New Data, and change Fetch from manual to one of the other settings.
flyinion
1,449
20
I can't update my apps. I click update and the button just reloads. I updated the OS when given the option a little while ago.
iTunes and App Store are having problems right now. I found out the hard way.......trying to set my new phone up this evening lol. Hopefully it's back soon.
williams77
