Why does device not supported show on screen when I try to charge battery?
I
iMore Question
why does " device not supported" show on screen when i try to charge battery
" device not support " started showing up on my screen when I try and charge battery. sometimes it will change and sometimes it wont
John Yester
Moderator Team Leader
May 23, 2012
8,847
Re: why does " device not supported" show on screen when i try to charge battery
Cable is going bad. Try and flip it and see if it works. otherwise you will need a new cable if not sooner then later.
Ledsteplin
Oct 2, 2013
50,995
797
108
It probably has a short in the cable. Mine do that way. You will need a new cable if you can't move it where it will work.
Sent from my ancient but trustworthy iPhone 5. ☮
No members online now.
l6onn44vy
