My use is to be able to work on digital art drawings on procreate and autodesk sketchbook at cafes and things. I love my cintiq 13hd but I'm sick of being cooped up at home!
Is there that big of a difference between the older generation and the new one? It's much cheaper to get a used older model. I hear it's not that big of a difference? Also, I hear the 64gb of the newer version is a sufficient amount of space, is the smallest version of the older model ok for memory?
I have an iPad Air right now and I love the procreate app, and it doesn't really FEEL like I would need the larger screen - but I am also used to working on a 13 inch screen. My surface pro 2 felt too small, but I was also running SAI on it, which needs more space on the screen to see all the options. Procreate is such a simple interface that would I really need the larger screen? I also want it to be easily portable to take around with me.
The point is, I want to make one good purchase because it's a lot of money. I wouldn't want to be unhappy after investing and just want an upgrade later.
Thank you!
Thank you!
