My phone's display is stuck in vertical mode. How do I get it to turn horizontally?
I
iMore Question
my phone is stuck in verticle screen mode won't go horizontal
billyboydoy
281
vertical and horizontal view don't work
Pul up the control center and off the rotation lock.
Sent from my iPhone using iMore Forum
ajl
784
Re: vertical and horizontal view don't work
That's called Lock Screen Orientation. Pull up control center and tap on the little padlock with the arrow going around it.
60,191
776
My phone's display is stuck in vertical mode. How do I get it to turn horizon...
1. Swipe up from the bottom of the screen to reveal the Control Center.
2. Tap on the last icon at the top right.
rolfe foxwell
Feb 21, 2018
​I have an LG Fortune phone using Android my horizontal feature on the screen stopped working the way I could fix it is to swipe down the entire length of the​ desktop screen and look at the bar at the top if you go to the lright of that you will see rotation
giving you the option to unlock the vertical rotation...​
Garrett11
