My iPad Air 2 won"t ring anymore when I get an incoming call on my iPhone 6s Plus. How can I fix it?
I
iMore Question
I am not tech savvy so I don't know where to go in settings to check or chane anything to make my iPad ring again or where to go if I need to change settings on my iPhone 6plus also. Can someone help me with this?
60,244
791
Re: My iPad Air 2 won"t ring anymore when I get an incoming call on my iPhone 6s Plus. How can I fix
Who set up your iPad to ring in the first place? Can you not get that person to set it up for you again, if applicable? In the meantime, check out the possible remedy via the following link.
http://www.imore.com/continuity-fix
elena4151
