Is Anyone Else Using the 80% Battery Optimization Setting?
60,265
796
If you’re referring to the Optimized Battery Charging feature in the Battery Settings then the answer is yes for me.
Wotchered
3,275
103
63
No, I'm not, can see no reason to, When I get up I want a fully charged phone for when I go out. I don't want to have to plug it in again to achieve this.
Ledsteplin
Oct 2, 2013
51,020
812
108
I'm not... which is probably foolish, but it drives me nuts!
I don't consider it foolish. I never use it. I charge up to 100%. No problems with battery. I think they implement a lot because of complaints. I manage my battery other ways for decent battery life.
  • Like
Reactions: Just_Me_D
60,265
796
I don't consider it foolish. I never use it. I charge up to 100%. No problems with battery. I think they implement at lot because of complaints. I manage my battery other ways for decent battery life.
Yep. It has adjusted to the times I put it on the charger and when I take it off. It’ll hold the charge at 80% and then slowly charge to 100% by the time I take it off the charger and begin my day. Awesome feature, in my opinion.
Ledsteplin
Oct 2, 2013
51,020
812
108
I did try using it. But I don't charge at regular times. I do a lot of charging during the day while using the phone.
  • Like
Jude526
Trusted Member
Jan 15, 2017
2,413
15
I don’t know if I will use it or not. Still thinking about it. The apps are still downloading on the new device.
shervin
