jerome g
Thanks guys. IP4 it is. As for the guy about AT&T won't let you use a pay as you plan. Doesn't mean you can't.
All you have to do is get a AT&T sim either from the store or get a cheap go phone. Either way do not activate or setup the account with the sim in the go phone. After you do all that throw the pin in the iPhone & you're ready. You can even change a few things to use the $20, 100-200 mb data plan option AT&T has on there pay as you go plan
I think that you would have to get a new sim everytime you want more minutes
or data. Once AT&T gets the imie and realizes you have an iPhone, they will add the data plan automatically to the sim you are using. It is probably doable, but you will have different phone numbers constantly for your contacts to keep up with.
