iPhone 7 replacement ear piece issue
alexrat1996
516
I got my iPhone replace twice one yesterday and one today the second replacement has something shiny in the ear piece when I was cleaning my iPhone screen.
The shinny thing in ear piece shows up when light is shinned into the ear piece is it normal or should I try the Apple Store again
pkcable
Q&A Team Leader, VR Expert
Jun 16, 2009
5,827
28
I'm not getting that at all. Are you sure it's not just a reflection of the light itself? Are you in any way scratching the ear piece screen, and causing it to become more reflective? In any event if you are not satisfied, then perhaps go for a replacement.
alexrat1996
516
It's the reflection of the light for sure since it's only shows up when light in shine to it.
Should I try apple it would be hard to explain this to them.
Tartarus
Feb 20, 2014
17,443
22
Unless the sound is weird or distorted, or the working of your iPhone is affected by it, there is no actual reason to go to the Apple Store.
Or you must really really get annoyed by it, then it's justified.
elena4151
