Iphone 4 audio problems
Joergen Mathiesen
Apr 22, 2015
My iPhone 4 has started to make scratchy noises through the speaker at playback. At first its occationally but after a few seconds the audio disappears totally and leaves only the scratchings. (Sound a bit like coffeemachine)
I changed the speaker, which helped the first minute or two, when the problem reoccurred.
I've tried DFU but unsuccessfully. Actually I found out that when disconnecting the battery I get same behaviour as when I changed the speaker.
Any ideas on what could cause these symptoms.
Best regards,
Joergen
59,790
647
None whatsoever. Make a genius bar appointment with the nearest Apple Store and have them diagnose the problem for you.
williams77
