iPhone 11 using battery fast.
mws_1984
264
I’ve been doing doordash lately so gps can be on often and it wastes away the battery. But even now without gps on it seems it’s still draining away fast.
Is there anything I can look out for that might be the cause?
60,556
938
Barring any rogues apps, I recommend you make a Genius Bar appointment at the nearest Apple Store and have them check it out.
60,556
938
Are they back to taking appointments? I do know my battery load level is low anyways. 88% I think.
The Apple Stores here in the Orlando area have been opened and accepting guests and appointment for quite some time.
Annie_M
Mar 2, 2016
22,702
951
I believe all stores are taking Genius Bar appointments. I agree tat it would be a good idea to have your iPhone checked out. In the meantime, you might consider purchasing a good quality car charger!
mws_1984
264
I have the original Apple charger in my car and a battery pack if not in car. It’s felt warm at times to. I know I don’t have the full life it used to. Could apps running or something to do with apps be drawing power.
Overnight at home I’ll get a full charge. But I’m car earlier on a 90 minute drive it just stopped charging at 84%
Shut phone off cause it felt warm. With cable in IMG_7669.JPGwhen I started back up still only got up to 87%
Blin
