HELP, iphone loaded with Quick pwn issue
rwsheffield
Apr 22, 2009
Hi, I have just used Quick pwn to jailbreak my 3G iphone and now it says no service on every sim card I have tried in it. Does anyone have a fix for this? Robert.
jamesus
TiPb Forum Staff
Jul 10, 2008
1,818
11
You are describing the difference between jailbreaking and unlocking. What you have done is jailbreak. What you are looking to do it unlock. You need to use Cydia to install yellowsn0w to unlock and use other carrier's sim cards.
Jeremy
Retired Moderator
Mar 27, 2005
6,807
251
www.iMore.com
Not really... he could have done a simple jailbreak and something went wrong, I've seen it before. But you may be right and the OP may be confused.
Jerrytg4
