Guys help me out to restore
Hansana
357
So when I got my new 7 plus I retired from my 6 plus backup. The glitches from that carried over to this and the battery life is not very good. Currently running 10.1 PB1. I want to restore back to the way it was out of the box and set it up as new. How do I do this?
Tartarus
Feb 20, 2014
17,442
20
Put your 7Plus in DFU mode and connect it to iTunes. Restore the device and set up as new. It really is that easy
59,860
664
Alternatively, you can simply go to Settings → General → Reset, and then select "Reset All Networks and Settings". After the process is finished, you will be met with the welcome screen like you were when you initially powered on the device.
Tartarus
Feb 20, 2014
17,442
20
No, iTunes will download the latest available official release.
If you initiate a restore on your iPhone you will stay on the beta though.
Hence my advice to do it via iTunes.
Tartarus
Feb 20, 2014
17,442
20
Why do you think they're on the Beta? I don't see it mentioned. It's part of my confusion.
It says iOS 10.1 PB1 in the OP.
Official release is iOS 10.0.2.
iOS 10.1 is beta. Additionally PB1 means public beta 1.
59,860
664
But won't I still be on 10.1?
Yes, you will. Having said that, if you want to remove iOS 10.1 beta, do as instructed by Tartarus and put your device in DFU mode and then select restore and update via iTunes when prompted.
tinktink09is
66
I did this myself actually.
Open itunes
Plug USB in your phone
Hold down power button + volume down until apple logo
Release power button, while still holding volume down
DFU mode comes up...restore/update
BigBawseEB
