Are you experiencing greater battery drain with iOS 14?
tabs31
May 15, 2012
8
Since installing ios14 yesterday evening in my 11 pro max, the battery drain has been greater than it had been in the past.
Anyone else experience this?
Thanks
wilber1
Trusted Member
May 13, 2013
18,336
Re: Ios14 battery drain
Always takes a few days to settle in hopefully two or three days and a couple of reboots will solve it .
xraiderv1
71
8
seeing this on ios-14 on an iphone 6s plus, and before anyone says its the battery, the battery IS brand new, had it replaced on july 16th.(I've had people saying this to me at times today)
A_M_W
104
Seeing battery drain also on my AW S5
Me too, a quite significant difference. I have just turned background refresh off, which I didn’t know was on. Hopefully that makes a difference. The watch weirdly seems to be taking longer to charge too.
xraiderv1
71
8
I just turned off background refresh on my phone. will see if that makes a difference.
..personally, I'm wondering whats the point of background refresh for things besides the weather and news apps?
EdwinG
Mar 10, 2012
4,073
659
Do you have hand washing enabled?
Apparently, that uses a lot of resources to listen and detect.
EdwinG
Mar 10, 2012
4,073
659
It’s on the watch… it s nothing to do with iOS.
Just replying to those that mention that the battery life reduced with the Apple Watch.
59,790
647
Thanks
Battery life with my iPhone 11 Pro Max has been great with iOS 14, and I’ve been running it since June.
xraiderv1
71
8
turned off background refresh on all but 9 apps..and went to bed with the battery at 96%. woke, turned on the wireless..came back to the phone after breakfast, played some gundam..battery's down to 93%.
so that sorted out the idle battery drain, but it still chugs the battery pretty fast when I'm actively using the phone.
RaRa85
49
8
I don’t think I’ve noticed any battery drain. All I know is Bruce Lee’s Be Water from ESPN is playing in PiP while I’m in the forums. This was my one must have feature for iOS and one huge reason why I switched over.
Just noticed that the system blocks out the picture. Loving this feature.
Spencerdl
Apple Watch Champion
Jan 10, 2013
41,122
193
63
The first day after the iOS 14 update I would say yes, probably because I was experimenting with the new widgets and features. It seems to have settled down or I have stopped messing with my iPhone so much now that I have set up the new iOS and finished experimenting...LOL .
Garz
Retired Moderator
Mar 9, 2009
8,172
155
37
I have been running iOS 14 since June. I wouldn’t even remember what iOS 13 battery life was like. Battery seems fine to me. Now I don’t run watch betas so when I loaded watch OS 7, I noticed significant less battery with the new watch OS.
FFR
3,321
408
83
Nope. Currently running iOS 14 on an 11 pro max and an Xs max.
Battery and performance have increased for me, especially on the 11 pro max.
Im also using the dual sim feature, which in theory should stress the battery more.
williams77
