Like many of the other iPhone 4S users out there, I was plagued by horrid battery life. I tried everything outlined here in the forums, until I reached a point where I didn't understand the point of having a "Smartphone" if I was turning all the "Smart" features off (Push E-mail, iCloud, etc) so I thought back to the methods I used with Android. This method may be outlined somewhere here, or it may not I'm not really concerned because I am putting my setup here and anyone is welcome to follow it and check their results.
Setup:
iCloud - Enabled everything to backup to iCloud
WiFi - Only on when somewhere with WiFi
Location Services (GPS) - Off; unless necessary
Email - Push enabled, 3 exchange server accounts
Brightness - Auto, I have it at 1/3 of the bar
Sounds - Ringer on, vibrate enabled
Network Settings - Data and voice roaming enabled
Time Zone Setting in Location Services - Disabled
Screen Timeout - 1 minute
And I never put the phone in Airplane Mode
This is a pretty Data hogging setup, so I'm sure the more that's disabled the better your results will be.
Here's the trick, follow these instructions CAREFULLY
Many of you may be familiar with this method, it's called Trickle-Charging and it can potentially damage your battery's lifespan.. but let's be honest, we are all going to get the iPhone 5 so our batteries will last us well until then
Here's a screenshot from the beginning attached, and I will update with one at the end of the battery cycle.
Setup:
- Unplug your phone from the charger and run it down to 95% battery
- Once it hits 95%, throw it back on the charger
- Let the phone reach 100% but make sure it has the PLUG icon, not the lightning bolt
- Enjoy your amazing battery life.
