problem with signal
youaintgotem
Oct 5, 2010
I have an iphone 3g that has no signal what so ever i have replaced the antena charging dock assembly and the wi fi antenna but still nothing as far as att bars im at a loss to what it might be!!!! keep in mind i have replaced the screen 2 times with no problems and replaced the antenna just cuz i was looking twards it workong and yes all the connections inside are connected any help is much apreciated!!
Slyfi
TiPb Forum Staff
Sep 12, 2010
700
32
hardware modification is alot trickier then software. mostly because you can't check if it works till its all put back together.
try opening it up and making sure everything is connected and if it is hopefully you took pictures of it all together in it original form before you started making changes.
williams77
