iOS 5.1.1 battery on 4s thoughts
LaDon08
Apr 30, 2012
31
11 days later and I've still yet to go in to look at usage/standby times.
I applaud you for not obsessing like I definitely do. I do however find it a little humorous that you are keeping track of the time....since you have kept track of the time....that your battery would last.
But seriously, I just in jail broke and put my mophie on in an attempt to just not worry about battery. Congrats man.
ModeratorOMD
Banned
Dec 7, 2011
587
12
I never understood how there could be a such thing as a "battery glitch" that could be solved in an update. If anything an update might save you battery life, maybe. But you can't control a battery with software.
You just got bad battery life.
kch50428
21,025
305
It is software that represents the state of charge or discharge... it is software that interacts with other components to decide to charge or not to charge , and how fast in some instances. You, motoleo, know not of what you speak.
ModeratorOMD
Banned
Dec 7, 2011
587
12
WhatI I was saying was that you can't use software to fix a bad battery. If the software isn't representing the correct battery levels or is draining the battery, that's a software problem.
mumfoau
Nov 6, 2011
5,651
9
My next thing, and I know this is unpopular, is turning off the battery percentage.
The thing notifies me when i need to start considering charging at 20% so I'm going to give it a try. :D
ThePinkChameleon
Trusted Member
Jul 8, 2011
10,873
485
83
You're doing great Pink!! :D
:)thanks, and you are as well;)
:eek: i've already tried this a couple mths back. It lasted for maybe 2 days. I just couldnt get past that one lol. BUT I wish you the best of luck conquering this one too!! I'll make ya a deal, if you last for at least 5 days, i'll give it a shot again as well:)
He11, we are our own support here LOL
:pthis is craziness i tell ya! LOL
mumfoau
Nov 6, 2011
5,651
9
Deal!! Lol
mumfoau
Nov 6, 2011
5,651
9
Once it drops below 95% (when the graphical battery drops from full) is when the urge to turn on the percentage kicks in.
mumfoau
Nov 6, 2011
5,651
9
Doing well thus far. Turned off the percentage late Saturday evening and it hadn't been on since. I think I'm gonna make that 5 days easy Pink!!
ThePinkChameleon
Trusted Member
Jul 8, 2011
10,873
485
83
:D good for you mistah m!! I'm actually gonna call your bluff & turn mine off today as well - we can go through withdrawals together lmao! :D
edit: just flipped that switch to OFF :eek: it looks strange lol
mumfoau
Nov 6, 2011
5,651
9
Woooooow... I wonder who will cave first
Redbird1
Dec 5, 2010
40
Hey gang,
I'm on my 3rd iPhone. It seems to me that after 6 months with each device, (one 4 and two 4S's. Lost the 2nd 4S) the battery started to drain significantly faster. Has anyone else noticed this?
BLiNK
8,225
350
Hey gang,
it seems to me, after time, everyone should do a little "spring cleaning" every few months. get rid of apps you do not use or take a closer look at the ones you do use. also, if you do not mind losing some info you can do a Restore as New iPhone and reset back to factory settings
sometimes just doing a Reset All Settings helps too [Settings > General > Reset > Reset All Settings] this combined with a battery cycle or two has helped me
williams77
