BreakingKayfabe
so if I restore as new but then restore from a back up immediately after, does that negate what i had done when i "restored as new"?
Exactly. Just defeats the objective.
figured. thanks! So then how would I get my contacts back on? Everything else I don't mind doing on my own. Outlook?
After finally being able to upgrade and jailbreak iOS 5.1.1. I must say that apple has finally fixed the battery standby drainage. With this version of ios, my standby have greatly increased. I'm not sure if usage have improved much but having a great standby time will results in slight increase in usage time. Before the update, I would be lucky if my phone lasted more than 12 hours without having to charge with my normal heavy usage.
Are you guys experiencing the same results? Keep in mind my phone is heavily loaded with jailbreak apps/themes and this stats is a result of heavy normal usage not iPod playback. Screen brightness at 60%.
If your contacts are on iCloud then all you would do is turn iCloud on, on your phone once you restore.
If you don't use iCloud then backup your contacts on Outlook and sync them back when done restoring
on iTunes.
has anyone noticed an almost immediate drain of 2-3% once removed from the charger? my phone tends to go to 98% within ten minutes of just a few texts, sometimes when not doing anything at all. if i reboot the phone, it goes back to 100% and then the drain seems normal. it appears the battery indicator isnt showing correct levels unless rebooted once removed from the charger at 100%. anyone else??
