How fast does this battery go down with light use?
CSI Guy
58
I am down 15% battery with light use in 2 hours, is that normal? Seems like it is going down faster than my iPhone 5.
jsntrenkler
Trusted Member
Mar 9, 2010
2,779
55
That's fast! I have not experienced a drop like that. For me I can easily make it through a full day although my usage does vary.
59,795
647
Same here. I recommend the OP go through each and every settings, and specifically, the location services settings, and make necessary changes, if any.
jsntrenkler
Trusted Member
Mar 9, 2010
2,779
55
I would give it a couple charge cycles and if this continues definitely schedule a appointment with your local Genius Bar.
anon(4698833)
Banned
Sep 7, 2010
12,010
187
Not at all normal. Light use should yield you at least 5-6 hours...probably more.
Apple covers their iPhone's, regardless of origin of purchase (within the states) within it's normal 1 year warranty period (or if Apple Care + was applied to it, extended times). You can bring it to the Apple store even if you bought it from an individual...it doesn't make a difference.
BreakingKayfabe
8,442
53
48
As already mentioned, it's all about what "light use" is. Last night I went to sleep at 10:30 PM and when I put my phone down, I was
at 92%. I did not put it on the charger. I woke up at exactly 6:30AM and it was at 84%. I had 4 new emails. Just the nature of the beast.
elvisx77
125
ImageUploadedByiMore Forums1383938378.684424.jpg this is my iPhone 5 with 40% battery remaining. Wifi on all the time.
Sent from my iPhone 5 using iMore Forums mobile app
elvisx77
125
Same scenario with my iPhone 5 after most nights. I don't think it's a problem.
leslie haw
90
Btw, is it true that the A7 helps save battery over the A6 due to its better efficiency? On the other hand, some says the 64 bit takes a heavier toil on the battery. I think I've been reading too much haha. Think I'm just not satisfied with my 5s battery life.
Jp8
