Help! Phone stuck on zoom mode!
lauriep05
58
I have had this problem a few times. Out of nowhere, the screens are all in zoom mode. But previously, the "magnifying glass" thing showed up, gave you the standard option, and it was fixed. This time, no magnifying glass, going into settings and tapping standard does nothing, and I have turned it off and back on four times (which has worked in the past) and still zoomed. This is really a PITA, so help! Please???
lauriep05
58
Thank you! That worked! I couldn't remember where it was in settings, and the screen was so large, I couldn't scroll around to find it. I turned it off completely so it won't happen again. Thanks again.
59,794
647
You're very welcome, and thank you for the update...:)
robbrick
419
www.dimensiondvd.com
When zoom is on, you can use three fingers to double-tap the screen to turn it on/off. Glad you fixed the issue though.
Sent from my iPhone 6 Plus using Tapatalk
vincie855
