Help! Dtunes And Mobile Theatre Gone???
Newuser1
Jan 21, 2010
23
I don't really know what happened but, dtuned and mobile theatre are no longer on my springboard. I went to cydia to see what happens and there is no longer a check mark next to the app. Whe I try to install it again it says
NOTE: The requested modification cannot be applied due to
required dependencies or conflicts that cannot automatically
be found or fixed.
Underneath where it says modifications it says.
Modifications
Install Appsync for os 3.1
Dtunes
Remove Bigboss recommended tools
Cydia installer
Diskdev-cmds
Essential
Mobile terminal
System-cmds
I upgraded a few things from cydia earlier in the day and then I noticed that I lost my cydia and mobile theatre. I don't know if one has to do with the other but I wanted to mention it.
I hope that someone can help because I had all my movies and music downloaded to dtunes. Thank you very much!
Dennis Anderson Julien
