Question re Charging iPhone 12 Pro Max: Using Apple's 20W charger, does it make a difference in charging time whether I connect that 20W charger to Apple's MagSafe magnetic charger which is magnetically connected to the iPhone 12 Pro Max, or is it faster to connect the Apple 20W charger to a USB-C to Lighting connector cable plugged into the iPhone 12 Pro Max? So as far as charging times, is the magnetic connection faster, or is the direct plugged in connection faster, or are they both identical? Thank you in advance
