USB C to C max watt fast charger?
David9723
Jan 18, 2015
8
I was looking for a faster way to charge my iPad Pro so i went out and bought a new charger that does 60W USB C PD.
I also bought a USB C meter that shows how many watts/volts/amps any device is using.
I am still un-able to even come close to the rated watts. I'm getting 12-15 watts my old charger was doing 7 watts.
Anyone else experience this? I'm using the cable the charger came with assuming it can do USB C PD 100 watts but just in case i have bought one that is rated for it.
Also why is there no multi port device with several 60W USB C with Power Delivery ports? I have more than one device that can take advantage of the tech.
TripleOne
Trusted Member
Oct 4, 2014
9,332
From what I know, PD for phones/tablets are maxed out at 30W.
It also depends on the battery %. If it’s 20-80% it’ll use more Watts, while 80-100% (trickle charges) takes longer and consumes less Watts.
Wotchered
3,188
90
48
I might have it wrong but does the usb-c meter connection in itself cause a lowering of the charging wattage ?
David9723
Jan 18, 2015
8
Using this charger and brand PD cables.
[redacted]
I pads battery at 26%, i get 25-31 watts. Use the iPads charger and cable it comes with i get 15 watts. interesting enough if you use the device it peaks at 31 watts
smitty22d2
