Respring to charge battery
fantasy_harbinger
Apr 2, 2010
Hi,
My iPhone 3gs is JBed. I just noticed a while ago that when I connect my iphone to my laptop, i hear the sound that recognizes the phone, itunes also recognizes the phone, but my problem is the battery bar in the status bar does not show that it's charging. When it's locked, it does not also show that it's charging. When I tried to play videos, turned wifi on, and made sure that battery will drain, the percentage stayed the same. So i'm assuming there's something wrong with the battery status.
When I respring the springboard, it now shows that it's charging.
Has anyone encountered the same issue? how to fix this?
Here are some of Cydia apps installed in my phone...
StatusNotifier
Backgrounder/ProSwitcher
Activator
winterboard
QuickReply
Alli
10,933
370
I have this occasionally as well. I hadn't thought of respringing to fix it, I always reset (which for me requires running Blackra1n). It's happened about 4 times since the middle of January, when it happened the first time.
TinaConsta
