Question iphone 15 pro max cases with privacy screen?
mws_1984
264
Has anyone found a case where it has a privacy screen? I found applying one to the screen and trying to use a case like a lifeproof to protect it, it just doesn't function right. Hard to swipe on anything or push on anything on screen. It creates a bubble of airspace having one on the phone plus the built in one in a case. Just been using the cheap rubber ones from walmart that just protect the sides. Even dropping it on its face cracked the privacy screen. But always liked having a lifeproof cause it is very rugged for drops etc.
Lee_Bo
6,130
332
68
There’s a very fine line between pretty and protected. You can protect your device or you can make it pretty, but rarely (if ever) will it be pretty and protected.
There are 100’s of “privacy cases” on Amazon. I’ve tried several but none of them felt like my phone was protected. I’m currently using a QuadLock case with a Spigen privacy screen protector and this has been the best combination (for me) since I’ve had my 14PM.
It should also be noted that as a photographer, I really don’t like the 100% enclosed cases.
  • Like
Reactions: Annie_M and FFR
poplolzz
