Help with t-mobile EDGE
Vderks
Jan 5, 2009
I have a 2G model running the 2.2 update. I am unlocked and operating on T-mobile. Everything works as expected except it will not connect to the Internet with EDGE. For full exclosure, I'm not very techy and paid a guy to perform the unlocking. Because everything else works I think it a setting that needs adjusted. The guy at t-mobile (who does not have an iPhone) tried to help without succes.
Thanks in advance,
Vicki
Jeremy
Retired Moderator
Mar 27, 2005
6,807
251
www.iMore.com
First you need to make sure you have a data plan on T-Mobile. Then you need to go into the settings and change the APN Network setting to the following:
User Name: wap.voicestream.net
Password: Leave Blank
Vderks
Jan 5, 2009
Ash,
Thanks for the reply. The nice fellow at the t-mobile store did that one only he was unsure. Bottom line-it didn't help. Any other suggestions?
Vicki
RowanJack
