Best way to keep the battery healthy?
Pandurr
Mar 18, 2015
23
What is the best way for keeping the battery on the iphone 6 plus healthy?
- Should you unplug the charger right after its fully charged?
- should you wait for the life to go all out before charging it?
What do you mean is the best?
Thanks in advance
- Pandurrr
kch50428
21,025
305
It depends... If you're using 3rd party chargers that are not "made for i" certified... I would not use those at all...but if you are, take the device off the charger when it's fully charged.... Otherwise, Apple and "made for i" Chargers will switch to a trickle mode when the device is fully charged and you don't need to worry about taking it off the charger. Once in a while, you can use it until it shuts off and recharge... Otherwise, just use it and charge it whenever, as needed.
david9962000
246
That's what I do, I let the battery run down to the point where the phone will shut itself off and charge it without interruptions all way to 100%.
EchoOne30
Jan 29, 2015
17
It doesn't matter what you do. These are li-ion batteries. They don't have memories or issues. Dropping it to zero or charging as soon as you hit 80% will result in the exact same battery health.
What these batteries have is a lifespan on charges. So leaving it plugged in means that the battery hits 100, then dips a bit, then gets energy trickled to it, then dips a bit, etc etc. keeping it plugged will just diminish the life of it. However you'll be getting rid of your device before that happens.
qbnkelt
5,213
6
33
I charge on the go as needed. I pay no attention really to the percentage.
DRizzlemeup
