Is anyone having ridiculous battery problems with the iPhone 6S?
iKev
318
Anyone else having ridiculous battery problems? This started a couple weeks ago (6s, running latest iOS). Last night, I restored as new, and here is my usage stats after doing so:
Additionally, the phone is HOT! Should I just head in to get it looked at?
anon(9602380)
5,828
Re: Genius Bar Appointment Necessary?
I would. If an Apple Store is conveniently close to you, why not? If it is not a battery problem, they should be able to assist you with what is causing the issue.
iKev
318
It ended up being the Overcast app that was causing the drain, even after deleting and reinstalling. That's a bummer. I loved the user interface of Overcast.
robertk328
Jun 7, 2010
8,988
Wow, glad you got it figured out. Heat is not a good thing
Urbanwoodsman1966
