Four Square was draining iPhone 6 battery but saw nothing in battery utilization
AB Lambert
260
All,
I figured out that Four Square was draining my battery on my iPhone 6. I started to notice my battery was draining faster than expected.
I went to look at the battery utilization feature and was only seeing the apps I was using at the top of the list.
I also was looking at the privacy feature and noticed that Four Square was always using the location feature (or just used it) when I looked. I decided to delete Four Square and noticed for 3 days after that my batteries performance improved significantly.
Has anyone had the issues?
Thanks,
A.B.
bamf-hacker
Champion
Nov 2, 2009
6,817
106
63
I am not sure if the FourSquare app has the option yet, but one of the new location features is to set an app to only use location services when the app is in use.
If you reinstall it you might want to check that.
AB Lambert
260
I did and the option was not available. I also try to see if I could do something within the App.
Thanks,
A.B.
bamf-hacker
Champion
Nov 2, 2009
6,817
106
63
The app developers need to update their apps to make it available. I am guessing FourSquare is focusing on their Swarm app :)
fabio984
289
EDIT: I don't want uninstall foursquare without be sure it drains my battery :|
Do you use swarm? I have it installed too.
Are you sure it was Foursquare? Can be coincidence...
You received less emails, or used the phone more with foursquare...
CrzyP
149
18
Make sure you also have the background location turned off in the app too.
smitty22d2
