Hey
Ok i will try and make this as clear as possible and give detail of what i did.
I brought an iPhone 3g that was currently on version 4.1. I wanted to jailbreak it so i could download some apps and such, I followed a guide on jailbreaking with redsn0w which worked great. However i think i downloaded too many apps or did something wrong as my iPhone battery was dying after just hours of use. So i plugged my Iphone into the pc and clicked restore on iTunes. Now this is the problem i read there are certain methods and processes to use when restoring/downgrading/upgrading jailbroken iphones. I guess i should of checked first. Well anyway, after the restore i tried to use redsn0w again just as i did when i first got the phone, but it keeps crashing. I once again used google and found out you cant use redsn0w more than once on a device and that i had to update and find another way of jailbreaking my phone.
So i am sat here with a iPhone 3g 4.2.1 and cant find a soloution. I just want to jailbreak it i dont care about unlocking it. I dont care which version i am on either. ( I am new to all this so i didnt save my SH.. Whatever they are called as i had no idea i had 2)
Any help would be appreciated
Thanks
Roadkill
Thanks
Roadkill
