AirPods Pro deal at Amazon: Save $52 for a limited time!
  1. PocketAces21's Avatar
    Sometimes when I receive a phone call, the call connects, but then no sounds comes through, and I don't think my voice is transmitting either. When I try to call back directly afterwards, the same thing happens. However, once I've restarted my iPhone, it goes back to normal. I can't pinpoint what causes this to happen. Can anyone help me with this? I'm posting here because my phone is jailbroken, and it may have something to do with one of the many cydia apps I have installed.
    01-21-2010 06:09 PM
  2. HAVOKID's Avatar
    What theme do you have? Do you have Live Weather Icon from Cydia?
    I had the same problem happen to me before so far, it seemed that some themes that have the live weather widget in they're wallpaper on they're LS or SB seems to conflict with the phone app's features. Removing that theme fixed my problem. I have another live weather widget in my SB wallpaper but doesn't cause the problem so I guess it depends on the way the script was written for the weather widgets on certain themes.
    01-21-2010 06:39 PM
  3. PocketAces21's Avatar
    I did in fact recently install that. Thanks for the tip!
    01-21-2010 10:34 PM
