Why does my screen black out during calls and phone not respond when activate voice and data over lte?
I
iMore Question
Screen blacks out during call and phone not respond when activate voice and data over lte
Love your podcasts. Have IPhone 6 on Verizon. Since turning on voice and data over lte every now and then on call screen turns black (like proximity sensor), but when happens is NO WAY to recover (or do anything on phone) till other party hangs up. Home button, and any other button, ceases working. When phone new last year, neither Apple nor Verizon could solve. Sent me new phone. Still has problem. Happens maybe once every two weeks. Have reset to factory, etc. Even happens before add any other programs. Finally took to Apple store this week and they could not solve - although they did find numerous posts in Apple support forum (some even this month, some old) with others with exact same problem. No solutions. They entered into some type of Apple database to bring to Apple's attention. Again, only happens when turn on voice and data over lte. When happens screen turns black and NOTHING works on the phone till other party hangs up, then phone is automatically ok.
Bigeric23
3,630
Re: Screen blacks out during call and phone not respond when activate voice and data over lte
I have that feature activated on an iPhone 6 and iPhone 6 Plus (both AT&T) and have no problems.
59,790
647
Screen blacks out during call and phone not respond when activate voice and ...
Same here, Bugeric23. No problems whatsoever in this regard. Anyway, OP, if you have a case on it, does it occur when the case is off?
Bigeric23
3,630
Re: Screen blacks out during call and phone not respond when activate voice and ...
That, Sir, is a great troubleshooting question. :gold-star:
Edward Weinberg
May 26, 2015
4
My understanding from posts on Apple support forum is that only happens on Verizon. Also, I have no case. Interestingly it really isn't just the proximity sensor staying on - as when the proximity sensor is on (try it by covering the sensor during a call), you always can return to home screen by pushing the home button. When this problem occurs the phone does not respond (stays black with the call in progress) regardless if home button is pushed. Does not "release" black screen until other caller hangs up.
This appears to be a widespread problem on Verizon Iphone 6 whenever voice AND data over lte is activated. Again, it is NOT a case or anything interfering with the proximity sensor itself.
Ledsteplin
Oct 2, 2013
50,287
710
108
A lot of users here with the 6 on Verizon. First I've heard of this.
Edward Weinberg
May 26, 2015
4
First - must have the voice and data over lte switch set. If you google the apple support forums you will find many messages citing this exact problem, some as late as this month. Apple store tech viewed the Apple support forum messages along with me last week and agreed messages were exactly on point. Are numerous messages with problem and it has been narrowed down to Verizon with that switch activated.
diogeron
Sep 9, 2015
05-28-2015, 09:15 AMEdward Weinberg
Does that mean you have to set voice and data or that is the problem? Unclear about the first sentence
diogeron
Sep 9, 2015
Same thing here. I took it to the verizon store and they told me the sensor must be dirty. Didn't fix it when I cleaned it. Very frustrating
LlammaMomma
Nov 6, 2015
I have the exact issue with my iPhone 6 and Verizon. It created an issue last night trying to call in a power outage and I could not get a keypad to show so I could press on the appropriate numbers, Is there a solution? What is the downside of using LTE only for data? How much does the voice quality degrade, and does that eliminate the blackout issue?
greyheeler
Nov 18, 2015
I've been having the occasional blackouts on my iphone 6 with Verizon. Only noticed it after updating to ios 9.1. Haven't figured out the trend yet., but it is a pain.
Hazard230
Mar 14, 2016
I have an iPhone 6 on the Verizon network with the same black screen during phone calls. DO NOT replace parts(proximity sensor) like I did. The issue is with the way Verizon uses Voice for LTE, this causes the iphone to go into a black screen and be unresponsive. To fix this go into your phone settings and set up LTE only for Data, not for Voice and Data. This should remedy the black screen issue on the Verizon Iphone.
Rob Phillips
Champion
May 1, 2012
13,759
I use VoLTE on Verizon all of the time with no black screen issue. Perhaps there's more to it than that.
Dennysiphone
Jun 21, 2016
I have LTE set to off for both data and voice and I experience the black out problem on Verizon with my iphone 6 plus.
williams77
