Why does mac OS Sierra drain my battery so fast?
I
iMore Question
Since the update my battery drains in a most excellent fashion.
XyThe Guy
Nov 2, 2016
11
You can possibly try to reduce brightness on everything. Like the screen, the backlit keyboard, and other things that you don't use (during the time of usage) like the bluetooth connection. You can even look into turning off apps that run in the background or automatic start up.
williams77
