Since jailbreaking iPod touch 4 has had much less battery life than it used to. Can someone help?
ironwaffle
Feb 2, 2013
5
Applist, apt 0.7 https method, bigboss icon set, browser changer, Cydia installer, Cydia translations, iCleaner, lowpowerbanner, mobile substrate, mobileTerminal, NoNewsIsGoodNews, Rocky Racoon 5.1.1, software update killer, substrate safe mode, swipeSelection, Tab+
Those are all the packages I have under the simple list. Does anybody know if any of these are possibly responsible? If I go into safe mode battery life is normal again so it has to be one of these.
3cit
3,044
63
Nope.
Are you sure you aren't just using your phone a lot more playing with your new jailbroken features? I.e looking at cydia a lot to see if you like anything?
Everything you mentioned is pretty standard stuff. Shouldn't be causing any battery issues
ironwaffle
Feb 2, 2013
5
ive had it jailbroken for a month now. I switch back and for between regular and safe mode. Every time it's in regular it always uses a lot more battery than safe mode.
3cit
3,044
63
the only tweak you have on your simple list that i dont also have is tab plus... so try disabling that tweak fro a few hours? i seriously doubt that its that though...
3cit
3,044
63
Sorry dude.
I got all tweaks you have plus many many more, and I even went through a battery crisis too.
I don't think I'm much help to you here as my battery is as good as its ever been
3cit
3,044
63
Well I never actually figured it out!
I really think it was just me being mental?
Like one day I had an issue, and then I decided something must be wrong, so i restored as new and started bringing tweaks back?
And I kept swearing that I had solved the issues, and decided it was location stuff, but in the end I never had a definitive answer.
I just turned off all my battery notices, nothing in the lock screen, or status bar or notification center, and I've been much happier!
I still get alerts when I hit 20% and 10% but that very rarely happens and I use my phone ALOT?
ironwaffle
Feb 2, 2013
5
It seems to have either been NoNewsIsGoodNews or SoftwareUpdateKiller because I disabd both of them and my battery problems are gone now. Strange, but whatever lol
No members online now.
vivekintech1
