Series 4 battery drain is rife
amzi160586
49
Hi all
So I have an Apple Watch Series 4 - 87% battery health and I’m noticing that the battery drain is like 7% per half hour - anyone have any insight on this. Currently on watch OS 8.6 and I’ve noted it’s getting worse each and every update Apple pushes out.
Surely the watch cannot be at the end of life this quick -
ksassy
1,139
120
63
I have a Series 5 and my battery health is at 89%. My battery life is okay but it’s not horrible either. I’ve noticed that the software updates for WatchOS 8 have done very little to improve battery life for me. If you’re noticing abnormal battery drain try a reboot especially after a recent software update as that usually clears it up. Whenever I update my Apple Watch I always notice higher battery drain initially so I force a reboot 1-2x to help it settle down. Hope your battery drain gets resolved.
tcuprof
Trusted Member
Aug 21, 2015
1,624
130
63
Something is definitely amiss. KSASSY's advice is exactly where I would start.
And no, the watch is definitely not at the end of life this quick.
pr1nce
Dec 3, 2012
26,003
57
37
I have a Series 5, battery health is 86%. My battery life has been good through all the watchOS updates.
I agree with the above suggestions.
amzi160586
49
Thanks a lot all for the replies and advice - I have just forced rebooted the device - currently sitting at 63% battery level as I write (08:50 BST) this and I will see where it lands at mid day 🤞🏽
amzi160586
49
As an update -
I put the watch on charge to get it to 100% and took it off at 10.45BST.
Since the hard reset, and now (13:35BST) I’ve lost 2% (which seems a lot more in line with expected behaviour given battery health at 87%).
However, the real test will now be when tracking activities (which will happen later this evening) - so will revert with an update.
Thanks for the hard rest advice
amzi160586
49
I think you can just replace the battery, and if I read it correctly, it would cost: £82.44 if it's out of service. If it's still in service, it would cost £0.
Source: https://support.apple.com/en-gb/watch/repair/service/pricing
I'm not sure how correct this is - the advisors I have spoken to have explained that the battery is not changeable as the unit is sealed in nature - so they would have to charge £ 366.44 for a replacement - definitely misleading, but at £ 366.44 is definitely not worth it.
Annie_M
Mar 2, 2016
22,005
784
Interesting. I got that from Apple's website, so it would be terrible if it was incorrect!
amzi160586
49
I know right, I just spoke to another advisor now, who is claiming the battery is changeable - but I just don't understand how, because it is not the norm for Apple to crack open a device that is fully sealed (and the Apple Watch Series 4) is a closed unit - then again, I could be wrong now that I have differing version for three advisors.
I'll take it in and see what they say.
Annie_M
Mar 2, 2016
22,005
784
Please let us know how it goes for you (and your Watch)!
amzi160586
49
Update:
Took the watch into Apple and they said that given the battery health is at 87% they would not recommend a battery replacement.
I have been monitoring the performance after the advised hard reset and it seems that having charged the watch yesterday evening to 100% @ 18.25, I have woken up 08.10 to the battery @ 64%. So a total loss of 36% over the course of the evening and night with no activities being tracked and just on my wrist during sleep.
What do you all think? Acceptable behaviour?
doogald
Trusted Member
Oct 23, 2012
2,758
97
48
Update:
That sounds close to mine. I always charge my watch an hour before I go to bed and usually wake after putting it on my wrist about 7-8 hours later with about 85% battery left. My watch (S5) battery health is 86% at the moment.
I workout in the morning, charge while I eat breakfast and shower, charge again (as I said) an hour before bed, and I always get through the day just fine. Most days my watch is at about 50% to 60% at 10 pm when I charge before going to bed.
amzi160586
49
A further update -
Watch fully charged to 100% as of 09.38.
It’s currently 13.21 and the battery is sitting at 84%.
Since taking it off charge, I have completed the following:
1) tracked a 3km outdoor walk
2) tracked a 14 minute cool down session
3) tracked a 65 minute weights session
So I think a 16% battery drain given over a four hour period and the level of activity tracked is ok.
I believe the hard reset had done the trick
Annie_M
Mar 2, 2016
22,005
784
A further update -
Glad to hear!
Annie_M
Mar 2, 2016
22,005
784
A further update -
Glad to hear!
williams77
