mms errors (random) help fix?
evolancer13#IM
Jun 25, 2010
40
So i have a jail broken/unlocked iphone 3g on 3.1.3 fw, and since i have had it i got mms enabled and working but up to recently, i have been getting the "The media content was not included due to a picture resolution or message size restriction"
I have it set up this way:
mms:
apn:wap.voicestream.com
mmsc:http://216.155.174.84/servlets/mms
mms proxy: 216.155.165.050:8080
mms max message size: 1048756
mms ua prof url: https://www.apple.com/mms/usprof.rdf#mn_p
any ideas what i have wrong or should do to fix this problem?
-Thanks
big9erfan
2,458
35
You should contact your carrier, they may have updated APN settings for their customers and since you have set yours yourself, would not have pulled the update.
If you're using TMobile in the states, they have an iPhone department and can help you.
planeboy
