Is there a battery case...
mattkerwin24
Oct 28, 2016
42
Is there a battery case for the SE that you can use a lightning cable to charge the external battery attached to the case?
Most cases I see require Micro USB to charge the external battery, I'm looking to not have to carry around a separate wire to charge the case for when I travel.
Thanks!
Carmen Chavarria
Oct 31, 2016
Hi. Hopefully I understood the question. I think you should look up the iPhone 5S Battery Case by Lenmar Meridian. I think that is what you are looking form
Dennis Anderson Julien
