IDevice stuck in safemode, please help!
TheJBShark
Apr 20, 2014
22
My ipad 3 seems to be put into safemode when I respring (all my tweaks are disabled), but there isn't the exit safe mode popup that usually appears since the Mobile Substrate update. The crash first appeared when I updated all in cydia, the updates were for activator, round screen corners (uninstalled this but no success) and another one (can't remember what it was called), that appeared in the update list when I added cydia.angelxwind.net and I can't find it in the tweaks list in Cydia. Any help would be greatly appreciated :)
iOS Gravity
4,071
Delete every single tweak until you find the source. If you aren't successful, you will have to restore in order to fix this issue.
TheJBShark
Apr 20, 2014
22
And on the website it say up to ios 6.X.X, are you sure it works with ios 7? (I really downy want to completely lose my jailbreak as there isn't one for 7.1)
williams77
