I want to know what the problem is and how to fix it?
DAmore Jordane
Oct 15, 2020
I just finished installing iOS 14 on my iPhone X, but for some reason my ringtones downloaded link redacted no longer play. I checked it very carefully in the alarm settings and reset it but when someone rings there is no ringtone. In this case I do not know what is the error, I want to know how to fix it?
Ledsteplin
Oct 2, 2013
50,287
710
108
Do you refer to the iOS ringtones, or purchased ones? You might try Reset All Settings. That fixes a lot of things. You would need to set the ringtones back up again.
FFR
3,321
408
83
I just finished installing iOS 14 on my iPhone X, but for some reason my ringtones no longer play. I checked it very carefully in the alarm settings and reset it but when someone rings there is no ringtone. In this case, I don't know what the error is, I want to know how to fix it?
Go to settings > sounds and haptics and make sure it’s actually on.
Best of luck.
Dennis Anderson Julien
