How to transfer ringtone from 6s Plus to 13 Pro Max
I
iMore Question
Hi guys,
So, I recently switched from 6s Plus to 13 Pro Max and I'm struggling to understand how I can now transfer a ringtone from my old phone to the newest one. Both phones have iOS 15.
I understand I can connect 6s plus to iTunes via USB cable that I have but the same solution will not work with 13 Pro Max.
What is strange is that my ringtone is not showing in iTunes app on my phone, it's not listed under 'Tones'. I honestly don't remember how I added it to my 6s plus because that was years ago but all I know is that it's working just fine and I need it to transfer it to my 13 Pro Max.
I realize the answer may be simple but I guess I got confused after researching this yesterday and I have no idea how to tackle this.
Annie_M
Mar 2, 2016
22,005
784
Hello and welcome to iMore. In order to continue this conversation, you may want to consider registering for an account here on iMore. If you're interested, click here to learn how to sign up!
Did you try going to Sounds & Haptcs? Go to Settings>Sounds & Haptics>Ringtones?
My tones have always transferred without issue. I would go on to the iTunes store and look up the specific tone. Since you purchased it once before, you should be able to download it onto your phone.
williams77
