AT&T/WiFi connection issues...
MrMars
1,331
6
I'm in the metro Detroit area. Network connectivity has been sketchy all day. Mostly noticing 4G and rarely LTE coverage. Not sure if it's my phone or an AT&T issue. Even noticing similar WiFi connection issues. Seems strange as I just recently "restored as new" my i5.
Sent from my iPhone using iMore Forums
59,860
664
Go to Settings - General - Reset and then select "Reset Network Settings" to see if things improve?
MrMars
1,331
6
Thanks I'll give that a shot. Now I'm wondering if it was my work place surroundings. I did reset while at work and still had issues. Once I left the building it seemed to get better. Who knows...I do appreciate the advice though. Was not aware that option existed.
59,860
664
You're very welcome, and hopefully, it'll fix the problem. Keep in mind, however, that some users are having issues sending and receiving iMessages and iCloud email, therefore, if that's part of the problem you're experiencing, the problem is most likely on Apple's end.
https://forums.imore.com/e?link=htt...om%2Fsupport%2Fsystemstatus%2F&token=auo2URjn
MrMars
1,331
6
https://forums.imore.com/e?link=htt...om%2Fsupport%2Fsystemstatus%2F&token=h7pJgEt0
Ah, I did notice some iMessage issues today also. Thanks for the info.
BigBawseEB
