I have strange problem on my iPhone 7 plus a1661 unstable ping and speed stats
Shahzad Ghani One
Feb 6, 2016
44
I have a strange problem on my iPhone 7 plus a1661 whenever I run Speedtest on it for my local wifi at first attempt I get accurate ping and speed but on second third fourth attempts it gives me very high ping and unstable speed what could be the issue? I had reset my network settings but still not solved
I have conducted same test at my android phone but everything shows up accurately even better speeds on my cheap android phone ! Not to mention I have no noticeable speed problem on my iPhone 7 plus while browsing or using facebook
Here is the screenshot of unstable readings on my iPhone 7 plus
Ledsteplin
Oct 2, 2013
50,283
710
108
Several things can affect signal and cause fluctuations. If you really want an accurate wifi speed test, do it on your computer. It's much more accurate than a phone. Are all the server locations the same?
Shahzad Ghani One
Feb 6, 2016
44
after trying different methods i came to know that is the ios speed test app which is not providing accurate readings after few tries......i tried ookla's speedtest web browser test from safari on iphone 7 plus and it is giving accurate readings...also tried same app on my iphn 6s ....same issue is happening there too... so it is definitely speed test app..for ios.....
williams77
